A Spark Plug question
Old Sep 14, 2000 | 12:44 AM
Rob4092's Avatar
I have a 98 Polaris Sport 400 that takes a NGK BR8ES spark plug.
I have a 99 Blaster that takes a NGK B8ES spark plug.
They both have the same gap.
What is the difference between the two and can I use either in both ATV's? I hate carrying extras of both.
Also, I've got a hopped up Banshee that uses a B9ES spark plug. Can I just get one plug to cover all three quads?
Thanks!
Old Sep 14, 2000 | 01:36 AM
VENOMOUS's Avatar
The R in the BR8ES just means it's a resistor plug. To my experiments of changing around with plugs they make no real difference. I used to run a B8ES in my Banshee but tried B7ES since it needed a hotter plug when it was first running and then tried a BR7ES. After I got it all straightened out I went back to the B8ES and then tried the BR8ES and for me I thought it might have gained power but I think the only reason I thought that is because I wanted it to be better. Bottom line it doesn't really matter except that machines that are supposed to have the resistor type plug should never change to anything than a plug that is made for the resistor ignitions and it doesn't hurt using resistor plugs in non-resistor machines.
Old Sep 14, 2000 | 07:55 PM
Rob4092's Avatar
I am a little confused with the last response. Any others?
Old Sep 14, 2000 | 08:26 PM
99WarMachine's Avatar
He's saying: use the BR8ES plugs in both quads.
Old Sep 14, 2000 | 09:54 PM
SaMs0nOLD's Avatar
I was running BR8ES plugs in my Banshee and was constantly going through plugs. Then I switched to B8ES and haven't had to change plugs since.
Old Sep 14, 2000 | 10:21 PM
VENOMOUS's Avatar
It was just the opposite for me.
Old Sep 19, 2000 | 06:57 PM
Rob4092's Avatar
Does anyone else have any experience with this topic and offer advice?
Thanks!
Old Sep 19, 2000 | 10:20 PM
rsss396's Avatar
rob4092,
The difference between the br8es and the b8es is a 5000ohm resister inside the plug to suppress igniton noise. Run the blaster and sport 400 on br8es if you don't want to buy different plugs you won't notice a difference. The banshee uses a colder plug than the other two so you will have to buy a seprate plug for it.
Old Sep 19, 2000 | 10:38 PM
87_250R's Avatar
the point is you can use any in any of the quads. OK!!!
chammerbeck
Jul 17, 2015 08:06 AM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Unzzy66
Jul 11, 2015 10:01 PM
Dirtbikemike1
Jul 9, 2015 01:27 AM
D-Hagz
Jul 4, 2015 02:19 AM
