basic mods to yfz 450
Old Feb 14, 2005 | 11:49 AM
easymoney1983's Avatar
Default basic mods to yfz 450
i just bought a new 05 yfz 450 and was wondering what are some of the first and basic things i should put on it to make it perform better can anyone help me out???? how are these quads and what have you done to your???? thanks for the help
Old Feb 14, 2005 | 04:01 PM
86LT250RFatty's Avatar
1) Dr.D Slip-On Exhaust (won the Dirtwheels shootout)
2) Pro-Design Pro-Flow Kit ( Your choice of a UNI or K&N Air-Filter)
3)GYT-R Jet Kit
Nice boost in power [img]i/expressions/face-icon-small-smile.gif[/img]
Old Feb 14, 2005 | 07:19 PM
drgnerth's Avatar
cam mod
Old Feb 14, 2005 | 08:55 PM
mucky's Avatar
3)GYT-R Jet Kit
and retard the exhaust cam 1 tooth
Old Feb 14, 2005 | 11:02 PM
blindside350's Avatar
3)GYT-R Jet Kit
You could get a Dr.D pipe from HERE for only $230 w/ S/A & w/o Quiet core...
Old Feb 15, 2005 | 08:22 PM
can someone explain why you would need to reatrd the exhuast cam 1 tooth and would the slip on give me as much power as getting the whole system does anyone have a slip on if so how does it compare to one with a new head also?? i am trying to make suer i put my money where i am going to get the best results
Old Feb 15, 2005 | 10:24 PM
Because the YFZ's stock head pipe is very well designed, and most copany's dont even make one because of that fact. The Dr.D slip on gives the YFZ a nice deep bark, and free's up the exhaust flow which gives you more power. Also, i dont know exactly why, im sure someone on here can tell you why, but retarding the exhaust cam one tooth does give you quite a powerboost, and some sights have step-by-step instructions on how to do it.
1) Dr-D Slip-on 230$
2)Pro-Flow with K&N or UNI ( 90$ - 120$ )
3)GYT-R Jet Kit ( 65$)
4)Cam Mod
Very good boost in power all across the board. this is the best way to spend your money on this quad. Plus, you need to do all this befor you can start modding the engine in the future, like bore kits, port and polish and so fourth.
Old Feb 16, 2005 | 07:10 PM
mucky's Avatar
retarding the cam puts the motor like the dirtbike motor and it does give you more power
Old Apr 29, 2005 | 01:49 AM
mudd4's Avatar
when u retard the cam(exaust correct???) where does it give u the power to...racing mx..how will it help..or not worth the time
Old Apr 30, 2005 | 12:14 AM
2fun's Avatar
Gives most on the top-end.
Some bottom and mid, but not much there.
Also, I would avoid the jet kit, and just buy the necessary jets/needle individually. You'll save yourself some money, and not have several jets that would be of no use to you.
Also, I agree, you probably won't see much (if any) benefit from an aftermarket header. Spend that 150-250 bucks on an aftermarket cam, intake, or suspension components (if necessary).
