Checking for Bad CV Joints ?
Old Jun 6, 2005 | 03:03 PM
caribou01's Avatar
Default Checking for Bad CV Joints ?
I am a Newbie and need to know How to check to determine if I have bad cv joints on the front end of my 2000 Kodiak. Also, If they are bad how difficult would it be to change them using a service manual for reference? Thanks.
Old Jun 8, 2005 | 11:23 AM
rolsmojave3's Avatar
they will make some loud noises kinda a poping/clicking noise...also...contact Danny thecvman http://www.thecvman.com/....very good guy to deal with..will tell you anything you need to know...i bought a Heavy duty CV for my Eiger from him and he helped me all the way with installing it
Old Jun 8, 2005 | 11:02 PM
THECVMAN's Avatar
Hey rolsmojave3,
Thanks I appreciate the referral. I do try to help. I'm glad to see that it's appreciated.
Thanks,
Danny
Old Jun 9, 2005 | 10:38 AM
caribou01's Avatar
Thanks, hey CV man do you have some kind of a how to instructions that come with your rebuild kits. I'd really like to do it myself if it is not too complicated rather than take it to a dealer.
Old Jun 9, 2005 | 03:20 PM
THECVMAN's Avatar
Okay, you asked for it:
CV Joint Rebuilding Instructions
Once you’ve removed the outer cv joint from the axle shaft place it in a vise with the splined end facing down. Make note of the position of the cage and race in the housing to insure that you reassemble it back the same way. Now use a small tack hammer or a regular hammer with a punch or screw driver to tap the inner race in between the ***** down inside the joint. This will force the cage up to one side exposing the ball. Use a screw driver to pop the ball from the cage window. Repeat this process all the way around the inner race until all of the ***** are removed. Now turn the race and cage assembly side ways in the housing with the cage window facing upward. Line the two cage windows that are going to be on the sides across from each other with the area in between the ball tracks (some cages have 1 or 2 cage windows larger than the others make sure to line these windows up to be on the side) of the housing and pull up. This should free the assembly from the cv joint housing. Once you have the race and cage free from the housing turn the race side ways in the cage and line up the area in between the ball tracks with the window openings and push one side into the window. This will allow you to pull up on the race and free it from the cage. Now clean everything thoroughly and inspect the parts for any wear dimples or pitting. If you drop the cage on a hard surface it should make a pinging sound, if not look closely for a crack because I’m sure you will find one. To reassemble the cv joint place the race back into the cage in the same manner as it was removed. Then place the cage and race back into the cv joint housing in the same way it was removed. Turn them both to make sure that you have them facing up in the correct direction as they were upon removal. Now place one ball into the cage window and tap lightly on the cage while holding the race to keep it from moving out of position to make contact with the ball. Once the ball is down into the track tap lightly on the cage and race toward the side of that ball to expose the next window and repeat the process until all of the ***** are installed. Now take your shaft (with the clip removed and place it in the cv joint and rotate it around (no more than a 30 angle) to check for the smoothness of operation. Then twist the shaft from side to side to check for looseness. It may have a little play just nothing excessive. Now take your grease packet and cut the corner of the bag to make it like a bakers bag and press it tightly into the hole were the shaft will go. Squeeze until you see grease come up around the ***** then set the packet aside for the next procedure. Now take the shaft (with the clip installed) and line up the splines of the shaft with the ones on the cv joint and press downward. You’ll want to use a screwdriver to push the clip inward while pressing down to get it centered. Now give the shaft a light tap with a soft hammer and the shaft should slide in easily until you feel the clip catch. It’s a good idea to give it a good yank to make sure it seated. Then take the remaining grease and make a bead around the top of the joint (ice cream cone shaped up toward the boot). Now slide the boot down and tighten the large clamp. Before you tighten the small clamp put a screw driver in between the shaft and the boot to allow any trapped air to escape then remove it and install the small clamp. Now you’re Ready to put the axle back into the vehicle. If you have any questions or concern you can call for technical assistance at 1-800-338-2326 M-Sat. 8-6 e.s.t. and ask for Danny.
Disclaimer: (the lawyers make me do this)
I offer these installation instruction based upon my experiences and knowledge of this procedure. I can not be held responsible for any damage or liabilities that may occur. These instructions are offered as a suggestion and not intended to offer guaranteed results. If you under take this task it will be at your own risk and no responsibility of CV Restoration or anyone representing them. If you disagree with these terms then I recommend that you refer the procedure to a trained responsible party.
Old Jun 9, 2005 | 03:53 PM
i wouldn't be to scared about the last part..the liabilty part....it's very straight forward and there isn't much of a way to mess it up if you follow those instructions
Old Jun 9, 2005 | 04:13 PM
THECVMAN's Avatar
I agree. But you never know, it's like they say "No good deed goes unpunished".or "When it's good it's good, but when it's bad look out for the lawyers". Just covering my behind just in case.
Thanks,
Danny
Old Jun 9, 2005 | 04:14 PM
yeah..you gotta love the sue happy people
Old Jun 9, 2005 | 04:17 PM
THECVMAN's Avatar
Amen!
slowgsxr97
Mar 18, 2022 03:40 AM
STLyamwar
Jul 25, 2020 04:44 AM
metal249
Jul 28, 2015 09:35 AM
Peter_
Jul 18, 2015 07:06 AM
musselmark
Jul 17, 2015 02:40 PM
