Need help For my Raptor660R 2001
Old Sep 15, 2005 | 06:34 PM
Tigger2518's Avatar
Default Need help For my Raptor660R 2001
Hi, I bught a JE piston kit 105mm (727cc) I m using a new Yamaha gasket and I change the hot rod. The engine is runing good but is getting to hot!! is trowinh water for behind from the little tank, what can that be??
thank you
Old Sep 16, 2005 | 10:05 AM
madracing's Avatar
head gasket. a stock gasket wont work unless its cut for the bore. what did you troque the bolts to
Old Sep 16, 2005 | 10:06 AM
welby's Avatar
Let me know if I'm understanding this correctly. You're using a stock bore Yamaha gasket set with your big bore cylinder?
Old Sep 16, 2005 | 02:18 PM
Tigger2518's Avatar
Yes you are correct, I´m using a stock gasket because the store send me that, I didn´t know that I have to change it. I already cut something on to fix better, is there any extra hold or something that I have to cut?
thank you for your help!
Old Sep 16, 2005 | 02:40 PM
Tigger2518's Avatar
I don´t understand your question...
How long shoul i hvae to cut it?
thank you for ur help!
Old Sep 16, 2005 | 03:04 PM
maddog56's Avatar
The stock yammi gasket is made for 100mm pistons, you have a 105mm piston, so your gasket needs to be openend up in the middle by another 5mm.
Old Sep 16, 2005 | 03:13 PM
Tigger2518's Avatar
Thank you very much! I´ll try that! do I have to used special gas??
Old Sep 16, 2005 | 06:35 PM
welby's Avatar
What gas you use depends on your compression ratio. You may be able to find a 105mm gasket from Cometic, I'm not sure, but that stock gasket is your problem.
Old Sep 17, 2005 | 12:27 AM
Tigger2518's Avatar
Old Oct 9, 2005 | 04:53 AM
RadRaptor's Avatar
I ordered the .40 over Wiseco piston and ordered the Cometic gasket top end kit. Will the factory one work with just a .40 over?
