which premix oil is best?
I run amsoil series 2000 at 50:1 in my 250R. I wouldn't run anything else. I never foul a plug, never have smokey exhaust, race it every weekend, practice a few times a week. Basically beat on it all the time and I never replaced the top end yet. The compression has never dropped yet.
I run Golden Spectro At 50:1 Its great, and easy to use, you mix one bottle to 5 gallons of gas.
1991 Lt250r :
Ceet seat cover,DG alloy front bumper,DG alloy rear grabar,DG alloy nerf bars ,Emgo bars,Pro design kill switch,Maier plastic(Looks awsome I put lots of cool stickers on it),Uni air filter,Shockwears,Parking brake block off,RTC clutch lever,Motion pro twist throttle(took a while to get used to!),Leager A arms ,Ohlins front shocks(got them with the quad the look kinda old),Homemade motor skid(from speed limit sign),Turf tammers on back,IPT hole shot up front,And probly other stuff to but I cant think of all of them rite now. Please go to http://www.screaminglt250r.homestead.com
1991 Lt250r :
#15
I run HR1 in my banshee and it runs great. I rebuilt it and started running it. popped the head to see how she looked and there isn't one spec of carbon on the piston. The walls look great. It burns very little smoke and smells nice. Doesn't irrate the riders that will always be behind me.
#17
Power Plus smells like strawberry shampoo. It is made by Manhatten Oil Co., somewhere in California.
I have been using it for several years. I am very pleased with it. No fouled plugs, clean burning, reasonably priced.
They make a 100% Synthetic and a Synthetic/Castor blend. I use the blend since I like the way the Castor smells when burned. It recommends 50 to 1 in water cooled engines. However, I run it at 40 to 1 in my modified Banshee just to be safe.
I also use it in my son's oil injected Blaster. It can be used as a Pre-mix and in Oil Injectors.
#19
WOW...ALOT OF CONTROVERSY.....THE BEST OIL IS THE
ONE WITH A NAME BRAND,CAN BE BOUGHT LOCALY(IF NEEDED IN A JAM)AT A GOOD PRICE TO YOU!!!
SEE, WAS THAT SO DIFFICULT???WHEW....AND FORGET
THOSE STICKERS,JUST FOLLOW THE INSTRUCTIONS ON THE
LABEL!!(20:1 WAY TO MUCH!!!) MY RECOMMENDATIONS ARE....GOLDEN SPECTRO (50:1) AMSOIL (50:1 OR 100:1
THERE ARE 2 TYPES) YAMALUBE (40:1) AND IF YOU DONT RACE DONT SWEAT IT,JUST READ THE LABEL!!
NOW GO RIDE
NOW GO RIDE
#20
Dude, the manual is saying thats what was recomended in 1988, now that there are better synthetics out. They recomend that u should up the ratio, just follow the label on the Premix and you should run fine. Did u foul any plugs when u were mixing it that rich??????
