hot cams
Old Oct 5, 2005 | 07:06 PM
MdotHolla's Avatar
Default hot cams
DO they make one for a honda 250x? My bike lacks alot of power in the lower gears(mainly 2nd) what do you suggest I do about this?
Old Oct 5, 2005 | 11:06 PM
1bad450r's Avatar
Default hot cams
If Hot Cams does make a cam for your bike im not aware of it. You could go with a WebCam, they make some good stuff for your bike. I would suggest maybe dropping a tooth on your front sprocket, for example going from a 13 to a 12, or getting a decent exhaust on there. Cams dont do a whole lot without a good intake and exhaust set up. Check out eBay, they have lots of stuff for your bike. For a cam, copy the link below and paste it into your address bar. Its a drop in cam and is probobly going to sell pretty cheap. Hope this helps.
http://cgi.ebay.com/ebaymotors/WebCa...QQcmdZViewItem
Here is a good exhaust for your quad. Better hurry on this one.
http://cgi.ebay.com/ebaymotors/honda...QQcmdZViewItem
Old Oct 6, 2005 | 08:39 PM
87250xman's Avatar
Default hot cams
Also try a full exhaust K&N and jetting.
Old Oct 7, 2005 | 08:00 PM
Leroy400ex's Avatar
Default hot cams
you are in luck, because Hot cams DOES make a performance Cam for your 250 x. if they make one for a 300 ex, they definately make one for your quad. i personally like to shop from dennis kirk. the web address is www.denniskirk.com and they usually have some pretty good pricing. but! cams add mostly to the mid-upper power. the bottom end power can be made up by putting a larger piston/ flat top piston. definately a good exhaust, and air filter will help you out. all of them together will make a helluva difference. thats my 2 cents worth
Scooter's Shop
23
Oct 22, 2015 07:04 PM
QuadRiders
Oct 22, 2015 04:13 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
Canamaniac!
Sep 15, 2015 06:19 PM
