250R Timing advance?
Old Oct 26, 2000 | 09:29 AM
DaveyR's Avatar
If I run a Cool Head or a milled stock head at about 215 psi compression, with race fuel, do I need to advance my timing? I've yes and no to this question?
Old Oct 26, 2000 | 01:17 PM
250R_Man's Avatar
You don't have to, but you can get a little extra mid range power if you advance your timing. I have an R that has a similar setup as you do and am running stock timing. It's not too critical, but like I said, you can get a little extra power out of the motor.
I would leave it alone.
Old Oct 29, 2000 | 09:52 PM
r42176's Avatar
I run a 330 cylinder with the crank stroked 4mm and 215lbs compression with the timing advanced 3 degrees. It was hard to tell if the advance did anything because I already have a lot of bottom and mid because of the increased stroke but you should feel a difference on a non-stroked motor. Running race gas you won't have a problem. The only thing I see is that the more you advance the timing the harder it is to start when it's cold. Likes to kick back on you.
Jeff
Sjrpp
May 2, 2023 03:59 PM
hugemoth
Jul 20, 2020 03:28 AM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
D-Hagz
Jul 4, 2015 02:19 AM
