Carb or Engine problems?
Old Oct 29, 2000 | 12:40 AM
hotfmfblaster's Avatar
I am hoping the collective here can give some advice on what I may check before visiting the shop.
The blaster will start and idle fine and for the first few minutes (about as long as it takes to warm) it runs fine. Then it begins to sputter and eventually dies. It will start back up and idle fine but when I try to take off it stalls.
I have checked all filters, main jet, pilot jet, replaced stock reeds with aftermarket, dumped gas, changed plug, and examined floats for debris.
I don't know where else to look for the problem. The engine is definatly knocking, could this be a pistion seizure problem?
Thanks.
arsenal@indy.net
Old Oct 29, 2000 | 09:04 AM
Diogenes's Avatar
From your description of your problem, and your previous posts, you may need a Raptor transplant.
Diogenes
Old Oct 30, 2000 | 12:57 PM
ERICsRAPTOR's Avatar
ha ha .. raptor
Old Oct 30, 2000 | 07:46 PM
free1steven's Avatar
Try a richer needle jet position. Move clip down to raise needle for richer mixture. Is your float height correct?
Old Oct 30, 2000 | 09:59 PM
r42176's Avatar
If it stalls when you give it gas then it sounds as if it is too lean. I'd agree with richening up the needle and try that. If the knocking sounds increases as you give it gas the you could have some major problems with the piston. Check your compression and see if it is what it is supposed to be.
Jeff
Hankey Pankey
26
Oct 18, 2020 03:50 PM
generalpops
Jun 5, 2015 08:23 PM
garyt1975
Jun 5, 2015 08:53 AM
generalpops
Jun 3, 2015 08:25 PM
kevbowe
Jun 1, 2015 01:17 AM
