1987 Suzuki 230s
Old Dec 22, 2005 | 07:12 PM
Minihucker01's Avatar
Default 1987 Suzuki 230s
This thing has been a complete nightmare from the begining...Im fixing this thing for my friend and its driving me nuts.... It started off simple...Smoked liek crazy and seemed like the throttle stuck....I rebuilt the topend to take care of the blow buy and did a head job...Cleaned the valves and all that good stuff...It looked like the throttle cable was pulling out of its housing and sticking when you let off down by the carb so i installed a new cable....Heres the annoying part..The thing still races like it has a vacuum leak....I sprayed the thing down to check for vacuum leaks with carb clean...Found one at the manifold..Fixed it and it made no difference.... The weird thing is, its not a constant high rev, it will idle fine one minute and the next minute without touching it, it will race to the moon.... I check the needle to make sure the clip was installd properly installed in the slide incase the needle was walking up a bit and allowing more fuel in....Not the case...I think its a carb problem but i dont know what could be causing this....Im about ready to find a new carb for it...Any input on this subject will be GREATLY appreciated! Thanks......
Old Dec 22, 2005 | 08:44 PM
DavidLT250S's Avatar
did you try adjusting your idol sqrew? my kodiak does that somtimes but only when the choke is on maybe you left your choke on?
Old Dec 22, 2005 | 10:47 PM
The coke is off, and the idle screw makes no difference....It does acts just like the choke is on....The weird thing is one moment it will race, the next it idles fine...
Old Dec 22, 2005 | 11:47 PM
JayMoneyDubs's Avatar
I have a 230 also and It has been one of the most reliable quads I had ever had. starts first kick. When I got mine I had the same problem. I even rebuilt the carb and it still ran not good....I took a carb off of my old mx 100 and It works perfect. Check the carb boot for any leaks.
Old Dec 23, 2005 | 01:12 AM
Bubba199's Avatar
when my 230 motor wa still in the chassis, i fixed that problem by taking the decompression valve out and threading the hole and putting a small bolt in it, like a block off...
BubbA199
Old Dec 23, 2005 | 06:08 PM
The carb boots are in good shape...I sealed the boot to the cylinder with rtv because it dide leak....Thanks for all the ideas...I will be sure to try them hopefully tomorrow after i hunt and i will post back with update.... Thanks...
Valder
Nov 28, 2020 07:38 AM
handyjc1
ATC 3-Wheelers
Oct 23, 2015 07:15 PM
Troylee216
Sport Quads
Sep 28, 2015 09:34 AM
Steeldon
Sep 8, 2015 10:51 AM
Sep 1, 2015 11:59 PM
