boondockers water manometer
ok how do u uses the boondockers water manometer i was thinking about buying the kit but what is this thing
should i save the time and buy a wet kit ? id perfer the dry kit how easy is it to tune the boondockers system i am familiar with automotive nitrous but am unsure of how you tune the boondockers kit any info is greatly apreciated and any other kits i should look at?
If I were you, I would'nt go with boondockers. There is a place called BossNoss. They have the only kit out there for an atv that you can control. With other nos systems, you don't ever know how much nitrous is going through your motor. It is 100% regulated, so you can hold the button down for as long as you want. The price is the same as boondockers also. You can check them out @ www.bossseats.com/bossnoss or 801-785-3413.
As far as the water manometer, don't know what that is.????
a water manometer is a tool used to measure low pressures, typically below 1 psi. it measures in inches or fractions of inches of water column and it is used where most gauges just are'nt sensetive enough. the is most commonly used by mechanics, hvac installers(manifold pressures) and the propane industry for system testing(leak,flow,lockup on regulators).
i have the boondockers on my ds and have not had any problems. yes it is a pain. but im one of those people who worry about hurting the motor so every time i fill the bottle i will check the system with the mammometer, but with that said im looking at the bossnoss aplication for my other 2 ds
I have run Boss and BD and yes the Boss system is really nice. Only problem with Boss is sometimes they are so busy that our customers have to wait a week or two for the product. I have not bought a manometer yet but it sounds like a nice way to check to see if the system is working.
Customer Service #1
05-15-2020 08:46 AM
jrooker6
04-23-2016 07:36 PM
