kodiak 450 performance cam
Old Apr 19, 2006 | 02:50 PM
squeege's Avatar
Default kodiak 450 performance cam
www.webcamshafts.com these guys will weld and regrind my cam....
thinkin of puttin one on with an exaust....what you think?
Old Apr 19, 2006 | 03:22 PM
squeege's Avatar
will run about $180 for cam and new valve gear.....worth the money?
Old Apr 22, 2006 | 08:27 PM
mrwake's Avatar
Yes! Extremely worth the money, you can determine a better powerband by which grind you get and gain a few horses. With an hmf and your set up you would need a cam, that is one of the limiting factors of power on these yamahas. When you do get it set up tell them to keep the specs because I would like a custom grind!
Old Apr 22, 2006 | 11:57 PM
squeege's Avatar
Thanks!
Old Apr 23, 2006 | 05:55 PM
mcain2's Avatar
I wonder if they could do the same for a wolverine 450?
Old Apr 23, 2006 | 09:43 PM
squeege's Avatar
They had it listed on the site....
Old Apr 24, 2006 | 01:15 AM
mcain2's Avatar
Sorry to bother you again with this, but I can only find it for the older 350 wolverine on the website. Can you tell me where I can find it?
Old Apr 24, 2006 | 09:48 AM
squeege's Avatar
You may want to call them...I did...You should have the exact same engine as the kodiak 450, but they will verify all that for you...
also...chances are you will need to send your cam in to them to have it ground..so you will get your own cam back with the new performace grind job on it...
Old Apr 24, 2006 | 09:19 PM
mrwake's Avatar
Currently this bike is needed too much around the farm to send it in but did you send your cam in?
Old Apr 25, 2006 | 09:47 AM
squeege's Avatar
No, just lookin' ....I got a paper manual for my quad to see what all it involves.....
Also, they wern't sure if they had the cam in sock, but if they already have one you could just order one from them and pay a core charge untill you get yours sent in to them
Customer Service #1
May 15, 2020 08:46 AM
YankeeRebel
Oct 6, 2015 06:44 AM
Sep 30, 2015 01:37 AM
jankerstien
Sep 21, 2015 03:09 AM
