comparing carbs, which one is best?
Old Nov 22, 2000 | 03:15 AM
dual-sporter's Avatar
i'm looking into getting a slightly larger carburator to increase the performanceof my quad
i have a '91 lt250r running stock mikuni 34mm.
mods that will affect it that are currently on the quad are: boyesen reeds, FMF pipe & powercore silencer, K&N filter, and a very mild port job(flashing & rough spots polished out)
i plan on adding a Delta V reed block or rad valve(but i'm undecided) and cool head in the near future. but now on to my question, with these mods in mind.
i ride it mostly in dunes.
which carb of the following will render the best performance for my setup & why? are there any difficulties with any of them that makes any others much better & why?
the three common ones i've found are:
keihin oval slide
mikuni round slide
mikuni flat slide
Old Nov 22, 2000 | 06:34 AM
macgiver's Avatar
THE SMELL OF NITRO IS BETTER. I WOULD ASK THE PEOPLE AT CARBPARTS.COM
Old Nov 22, 2000 | 02:51 PM
THEXOTIC1's Avatar
Lectron makes the best flat slide carb. If you replace the carb get a flat slide carb. i would get a 36mm
Old Nov 22, 2000 | 09:01 PM
SandDraggin's Avatar
The best performance carb on the market next to the ultra expensive Lectron is the Kiehan D slide carb. I think they range as small as 36mm
Cole Hadden
Jun 15, 2025 09:05 AM
RedRancher
Oct 15, 2020 01:45 PM
GregM
Mar 6, 2018 06:53 AM
Aitch
Jul 21, 2015 09:40 PM
