pred 558 big bore?
Old Aug 7, 2006 | 04:44 PM
1fasstpred's Avatar
Default pred 558 big bore?
is the 558 bid bore reliable and do i have to run race gas or is pump gas good to?
Old Aug 8, 2006 | 04:08 AM
1fasstpred's Avatar
anyone?
Old Aug 8, 2006 | 11:32 AM
2001Bansheeboy's Avatar
you should be able to run pump gas, unless you raise the compression a lot, although premium pump gas, is probably a good idea. About it being reliable, it really depends on what else you do to it. But it should be fairly reliable still. Tell me how it turns out, i might try one for my pred.
Old Aug 8, 2006 | 04:17 PM
1fasstpred's Avatar
whats the highest compression i can get without having to run race gas?
Old Aug 8, 2006 | 11:02 PM
duneittilludie's Avatar
11.5:1 is generally considered to be the highest that you can go and still use 93 (pump premium) but there are other factors to consider such as porting and its effects on compression.There are quite a few old posts you could search and get much more information on this subject.
Old Aug 16, 2006 | 05:11 PM
honda400rider's Avatar
doing almost any type of engine mod will bring the reliability down. something like boring causes the engine to not handle heat as well because of the thinner cylinder wall.
if you go big bore, you will need to do some other mods to get it to run right. pipe, air filter, re-jet are must haves. to get even more out of it change cams, port and polish, and replace your valves and get stiffer valve springs.
BYC
Sep 25, 2015 02:10 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
