fuel additive?
Old Feb 15, 2007 | 11:17 PM
Raptor660JC's Avatar
Default fuel addative?
Whats a good fuel additive to mix in with the gas every so often to clean out the carb/lines/engine and such?
I see some posts regarding seafoam but it seems like a mixed crowd, the same amout that like it seem to dislike it, anything else that will work well?
Old Feb 16, 2007 | 09:44 PM
UBETRUN's Avatar
Default fuel additive?
Seafoam is good stuff as is Yamaha Ringfree. Don't try to drown your engine in the stuff and you'll be fine, just a little in every gas tank will clean out the gunk over time.
Old Feb 17, 2007 | 01:53 AM
Doctorturbo's Avatar
GOT BOOST!
Fuel lines and the engine should never need to be cleaned ( inside anyway). If the carb needs cleaning, take it off and clean it. If you engine needs cleaned inside you need to tune it better or rebuild it.
SureCanUSA
Sep 14, 2015 09:57 AM
PrairieDog126
Sep 12, 2015 06:53 PM
gogogo
3) General Discussions..
Sep 8, 2015 08:49 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
Elkaholic
Sep 6, 2015 02:44 PM
