Will this work??
Old Mar 8, 2007 | 04:54 PM
1988fast250x's Avatar
Default Will this work??
Does any one know if a 300ex cylinder just the cylinder can fit on the 250x?? the engines are the exact same as far as i know except for eletric start and a longer stroke and little bigger bore.... if the cylinder fits i will put it on my 250x and put the valve train of the 250x back on it... then i will bore that out and then get my botom end cut so the piston will fit in it... well then add the crank i already have waiting to stick in.. 12.5mm... thanks for the help...
Old Mar 17, 2007 | 11:12 AM
RexSi's Avatar
you asked if it would just "fit in" then said you were going to bore it out ?
I thought they had the same block just the bore size was diff.
So you should be able to bore the block and be in business.
Old Mar 18, 2007 | 09:40 PM
figured it out.. there the exact same can be bored the same.. the only difference is the 300ex has a longer stroke.. making it a 280 something... So i didnt waist my time.. I already have an 80mm big bore in my bike.. but i thought i could get a bigger cylinder and go bigger on that bore...
hugemoth
Jul 20, 2020 03:28 AM
rcappie4
Jul 18, 2015 07:51 AM
timster911
Jul 13, 2015 01:57 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bikedad3
Jul 2, 2015 02:15 AM
