Toomey Jet Kit??
Toomey buys Dynojets that they've found work well with their pipes. I've got both and the throttle response is awesome. The most expensive item are the needles. If you've already got your pilot and main where you want them and the throttle response is good, it's probably not worth it. If you've only messed with the main and the response isn't what you'd like, it probably is.
You are better off buying one of the kits available. The length and taper of the needle is where it's at. It makes for a SMOOTH transition from part throttle to full. It will take you forever to find the right combo on your own.
I bought a needle/jet kit, along with my pipe kit from LRD.If I remember correctly, it was about half the cost of the DynoJet kit.
It might be worth giving them a call.
