modding a frame
Old May 3, 2007 | 02:27 PM
fartman's Avatar
Default modding a frame
I want to relocate the A-arm brackets to under my Mojaves frame intead of above it. I am doing this because I have added longer shocks and now the quad has a bad stance. Like a V. So I believe by lowering the mounting location I will improve the stance and allow the wheels to sit straight.
Anyways my question is what would be the best way to cut the brackets off so I can relocate them without hurting the frame. I was thinking of using a cutoff wheel and split the weld enough to pry them off.
Another question is what is the better way to weld onto fram mig or tig?
Thanks ,
Jason
Old May 3, 2007 | 10:59 PM
Doctorturbo's Avatar
GOT BOOST!
I would use a cut off wheel or a cutting torch. Grind it smooth and weld some new brackets on.
The best way is to tig them on. A mig will be fine, but you said the better way.
Old May 4, 2007 | 12:28 PM
fartman's Avatar
Thanks Doc,
Old May 7, 2007 | 03:31 PM
Tpsycho's Avatar
My Bomb Busa is done now and WOW what a rush this thing is scary fast. I love it
Why don't you put extended A arms that was the intentions of the longer shocks.
Old May 7, 2007 | 05:11 PM
fartman's Avatar
Its for a 110 mo, not the 250. I have not seen any for a 110. I am thinking of maybe buying some off e- bae and having them extended.
EIF
Apr 20, 2017 07:15 PM
scrounga
Honda Side by Sides
Mar 7, 2016 04:17 AM
Sep 23, 2015 06:23 AM
PrairieDog126
Sep 16, 2015 01:33 PM
1ArmBandit
Sep 8, 2015 08:59 PM
