Stuck bolt, stripped, and stripped again, cut, help cant get it out
If you have a steel bolt and aluminum case, then
get a can of freon gas, once you have a wrench or what ever tool to give you a good bite, carefuly use the freon gas to freezzzzzz the bolt, the steel will shrink in size while the aluminum stays the same size, then try to remove the bolt, I have done this many times. *** Note: Use the Freon that is freindly to the ozone would not like to tee off the eviro's Ron
BrokeMyBanshee, go to this site:
http://www.helicoil.com/products/helicoil.html
Helicoils are invaluable tools for repairing stripped threads in aluminum.
broke...you should be able to see the visegrips I'm talking about at this link... http://www.mytoolstore.com/american/vis003.html
I got mine at Menards but they have them at Home Depot too [a little cheaper at Home Depot]. The great thing about them is they actually force the nut/bolt head into the "V" so there is no way they can strip unless the bolt is already so shot that it needs to be drilled out.
#16
Broke..another thing to remember{s}never overtorque bolts going into aluminim set to proper specs,on older threaded holes it's good idea to "chase" threads with tap,clean up bolts on wire wheeel prior to re-assembly.
If a bolt seems to be stuck a little heat goes along way.
99warmachine ...greatwebsite! I ordered catalog& cd.
#20
yeah, pretty sure, here is a picture http://www.geocities.com/jibaridge/bolt.jpg
Its such a small bolt but it fights like a big one, still havent got it to budge at all, had a buddie over today and he had a try at it..
