Warrior performance questions
Old Nov 21, 2007 | 12:07 AM
recon99's Avatar
Default Warrior performance questions
But... is it compression adjustable, and does it have a reservoir. A shock for a 190 lb rider will be too soft, although your stock ones are also probably too soft in that case. If it's compression adjustable you can adjust how soft it is, without it, you have very limited adjustability.
Old Nov 21, 2007 | 07:26 AM
tedsxb's Avatar
I see. Thank you recon for all your help. I will report back with what I come up with and how my mods turn out.
Old Dec 1, 2007 | 10:37 PM
tedsxb's Avatar
Well, I spent 4 hours trying to put jets in my carb. First, WHAT THE H$@# DOES YAMAHA USE TO LOCK THE BOLTS TIGHT? EVERY F#$%#$% SCREW IS STUCK!? Second, How do you install a new main jet in the carb? I thought you unscrewed it, but I cant see any slot for it. I NEED HELP!
Old Dec 2, 2007 | 08:31 PM
tedsxb's Avatar
I finally figured out my jet quandary. I was looking at the wrong piece, but the instructions dont even mention removing the bowl, which is necessary. I got the screws out using a small vice-grips. Also, I found a brand new K&N filter at a garage I was cleaning out, and wanted to fab a collar up for it to run it without the airbox lid. However, It is about half the size of the stock filter. Will it flow enough?
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
manuelrivera
Aug 8, 2015 04:34 PM
suzukiquadrunner1987
Aug 6, 2015 05:29 PM
Ashley S
Jul 31, 2015 09:46 AM
