440ex mods
Old Nov 19, 2007 | 05:35 PM
440_man's Avatar
Default 440ex mods
hey guys i have an 02 400ex with a wiseco 440 12.5:1 compression, stage 3 hot cam, hot rod heavy duty crank shaft, and fmf powercore IV exhaust w/powerbomb header. now im looking to either ad a rev box or new carb. anybody have any suggestions for either? also, if anyone know how much either of these effects performance good or bad let me know thanks!
Old Nov 19, 2007 | 10:13 PM
pw383426's Avatar
Default 440ex mods
I haven't done a hot 440ex set up like that, but I have done mild ones.
In any application, when you're going to add more air and fuel like that, more cc's and more cam, it would be wise to have someone port your head and get a bigger carb. Your motor is basically a pump, and you've made the pump bigger but now you're restricting it with factory side carb and ports.
There should be a BIG difference if you save up some coin for a GOOD port job, and an aftermarket carb. Those parts you have already installed aren't living up to their potential without letting more VOLUME of air and fuel in. Get it?
Old Nov 19, 2007 | 10:38 PM
ctateusa1's Avatar
Default 440ex mods
I would also add the rev box if I was you. I think dynatek probably makes one for you, I have heard they are a good company for cdi boxes.
Customer Service #1
May 15, 2020 08:46 AM
Sep 23, 2015 06:23 AM
PrairieDog126
Sep 16, 2015 01:33 PM
1ArmBandit
Sep 8, 2015 08:59 PM
JakeXBL
Sep 5, 2015 01:08 PM
