what first???
Old Jul 27, 2008 | 02:55 AM
WV250ex's Avatar
Default what first???
I already have a pipe and filter on my warrior, what is the next thing to do? i dont care if it means getting in the motor....
Old Jul 27, 2008 | 12:50 PM
Krait's Avatar
Jet kit, camshaft, higher compression piston, CDI, port & polish, stoker crank, oversize piston, header pipe...
Old Jul 27, 2008 | 02:54 PM
ATV_MAN's Avatar
You have to look at your riding habits, what do you want most from your quad? How much do you want to spend? The best thing to start out is what you've allready done, get more air in(filter) and more exhaust out(pipe). If you get a cam I would bore out the engine as well. Upgrading smaller things can help out the power, CDI, jet kit, even sprockets can change the accelleration or top speed of your quad, better tires can help you 'hook' up on the trails you ride. Keep your quad maintained, change the oil, spark plug(gap too), clean the filter on a regular basis, it will help.
Old Jul 27, 2008 | 05:42 PM
redrider52's Avatar
id get a swingarm skidplate if your riding trails. not too expensive and easy to put on.
Old Jul 28, 2008 | 02:56 AM
Painkiller's Avatar
when you say pipe, do you mean a full exhaust sytem (headers and muffler)? or do you just have the slip on? just the header?
Old Aug 1, 2008 | 07:54 PM
WV250ex's Avatar
I only have an aftermarket muffler.....
Old Aug 1, 2008 | 07:57 PM
WV250ex's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: redrider52
id get a swingarm skidplate if your riding trails. not too expensive and easy to put on.</end quote></div>
I have full skids, im looking for more power tho.. I would like some more power overall, low and top end...
Old Aug 17, 2008 | 01:25 AM
Yammer rider's Avatar
web cam and a wiesco port and polish if u wanna go really fast lol
Old Aug 27, 2008 | 05:56 AM
ATC250R4ever's Avatar
Man, the sky is the limit with what you can do to your quad. I would start with suspension, personally, but that's just me. Since you have the exhaust and the filter, jet up 2 stages so you don't burn a hole in your piston (it happens, trust me) and port and polish your head. Add a HOT CAMS stage 1 cam and see where that takes you. If you still want more install a big bore kit. And if that's not enough, get a Banshee and start over.
