Custom Exhaust
Old Jan 15, 2009 | 06:04 PM
generaltroylee's Avatar
Default Custom Exhaust
This is my first post so I will start off by saying hello to everyone.
I might be doing a 2stroke dirtbike motor to atv chassis swap here in the near future.So my question is this...Do any of you know of any places that make custom 2stroke pipes?
Old Jan 15, 2009 | 06:39 PM
brian 68's Avatar
i think paul krause , side winder sprockets, used to run ads in the old magazines. for custom pipes , i have done several 2 stroke conversions, usually try to make the dirtbike pipe work, i do cr 500 conversions , i thought about getting a pipe for a big bore 250r , what are you working on,
Old Jan 15, 2009 | 11:21 PM
KTM 300exc to blaster swap.From the way its looking the pipe/radiator is going to be the hardest part.I already have a reinforced blaster chassis.Which used to hold a 240 kit motor.Got rid of the motor due to needing cash and now need to put something back into it.That KTM motor is calling my name.
Old Jan 16, 2009 | 11:04 AM
brian 68's Avatar
there is a trick i use for vibration , when you mount the motor , i weld a u shaped piece of 1" tubing into both mounts upper and lower front, it doesn't have to be completely hollow just the last 3" weld a nut on the end , and fill the tubes about 3/4 full of bee bee's . the bee bee's will take out any resonance vibration. i'm trying to get set up to upload pict's this week , if your unsure. as far as the radiator goes you might try a suzuki quad racer style mount's on top of the front upper frame [ where the shocks mount to ]. as far as exhaust goes i would look at the factory weld's if it was cut at the factory seam's could it be rotated and made to work, if so take it to a good exhaust shop and tell them what you want if they arn't to swamped they should be able to help. or plain welding shop, fabracator. but it's going to cost.
Old Jan 16, 2009 | 07:08 PM
Sounds like you done this once or twice![img]i/expressions/face-icon-small-smile.gif[/img] If it isn't a problem I would love to PM you with my email address and get some pics for references.
Old Jan 16, 2009 | 09:08 PM
brian 68's Avatar
no problem, check your pm
Pehter
Oct 3, 2024 11:00 PM
mrtidy
Feb 3, 2016 05:00 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
cboler9
Sep 24, 2015 08:35 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
