need BLASTER to be FASTER THAN A 300ex
Old Mar 2, 2001 | 01:05 PM
01MXBLASTER's Avatar
MY FRIEND HAS A 98' 300EX WITH A CURTIS SPARKS PIPE, REJETED CARB, K&N FILTER, 20 INCH RAZORS, HOW CHEAP AND WHAT CAN I DO TO STAY IN FRONT OF HIM THE WHOLE TIME IN A DRAG RACE, HELP
Old Mar 2, 2001 | 01:17 PM
2fiftyX's Avatar
Buy a 400ex, $4,700!
Old Mar 2, 2001 | 03:21 PM
umm no, the whole point is to make a blaster beat a 300ex buying a 400ex is cheating
Old Mar 2, 2001 | 03:40 PM
2fiftyX's Avatar
OK! Put a 400ex motor in your Blaster frame. Or even better yet a yx426f. Problem solved.
Old Mar 2, 2001 | 03:41 PM
2fiftyX's Avatar
That would be a yZ426f not x!
Old Mar 2, 2001 | 05:25 PM
that would still be using more displacement, i want a 200 to be faster than a 300, do you know what would happen with a 426 in a blaster, that would be faster than a raptor and about half as stable
Old Mar 2, 2001 | 06:09 PM
jtblstr247's Avatar
O1MXBLASTER my friend has a 2001 300ex with a FMF MegaMax Exauhst and Header, K&N Filter,and 20 inch Holeshots. My Mods on my Blaster are listed below in my Signature. I waste his 300ex every single time we drag race in the desert. So if you want to be faster than a 300ex get the mods I got and more.
Old Mar 2, 2001 | 11:10 PM
thanks, but whats the highest gear your blaster will raise up in with the 1 tooth bigger sprocket
Old Mar 2, 2001 | 11:46 PM
jtblstr247's Avatar
It will stay to 6th
Old Mar 3, 2001 | 01:27 AM
philzie's Avatar
What mods do you have now? If he didn't change his sprocket, he has already reduced his gearing with the smaller tires.
Mill the head for more compression, and a little power.
Try a 1 tooth larger front sprocket.
With higher gearing you should be able to pull him in a long race, but I am not sure how you will do off the line.
