mojave power?
Old Aug 12, 2001 | 11:58 AM
jumpinmojave's Avatar
i bought a mojave about 5 months ago and I was wanting more power from it but wanted to go in the right direction. I have a couple friends w/ blasters and one went the right pipe/silencer choice and one didn't. i blow away the one that didn't chose right but the other one blows me away. I was wondering What I can do to increase power but there are different things I want so here theye are:1) i need a pipe that is quiet but has a good grunty sound over stock. 2) i want to be able to have a lot more low end torque so i can weelie more easily because my powerband doesn't kick in until way up on top end. 3) I also do a lot of mud and water riding and Am planning on putting on sur trac tires and don't want a power loss in the mud.
if anyone can answer some of these questions I will be greatly appresiated....
i was also wondering about mordr's mojave and his pipe he has on that, mordr if u can e-mail me at jumpinmojave@aol.com that will be cool. Thanx
Old Aug 12, 2001 | 03:44 PM
pineman's Avatar
Get a local engine builder to degree your cams for low end power.
Old Aug 12, 2001 | 11:36 PM
MEANGREENMACHINE's Avatar
Get a supertrapp ids2 pipe. It gives a lot more power over stock and sounds great. It is a very low grunty sound. Then get a 12 tooth sprocket for the countershaft. That will let you wheelie much easier and doesn't take much off of top speed. Get a k&n filter to let it breathe better.
Old Aug 15, 2001 | 05:17 PM
mojaveaddict's Avatar
a 12 tooth frt sprocket is what a stock mo has. for more torque you can change to an 11 tooth, but you probably wont like it.
Old Aug 15, 2001 | 05:55 PM
You're right mojaveaddict. We dropped down one tooth to an 11 tooth front sprocket. It did make a difference low end but the top speed probably took a 5 mph loss. It is great for trail riding but not for wide open racing.
Old Aug 16, 2001 | 12:51 PM
mordr's Avatar
I would NOT eliminate the air box and go with and go with a clamp on if you were thinking about that-if you plan on sticking with the mud and water running-just a thought.
MeadowlarkFarm
Nov 27, 2019 08:40 PM
bvolks
Sep 13, 2015 12:57 PM
scorpiankill
Sep 10, 2015 09:14 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
byronman
Sep 6, 2015 06:34 PM
