Single carb setup for banshee
Old Feb 3, 2002 | 02:07 PM
bansheeguru's Avatar
Has anybody tried trinitys single carb setup for the banshee??? did it help the bottom end torque?? is it worth the money?? How did it effect the top end power??
Old Feb 3, 2002 | 03:21 PM
seven's Avatar
It will help the bottom end a ton, MUch easier to ride and keep in the power. But the top end sucks! So you have to make a choice on what you want for power
Old Feb 3, 2002 | 03:32 PM
the500bansheepilot's Avatar
Another thing to consider aside from the performance would be increased simplicity ie. only one carb to jet, one clamp on air filter andv one throtle cable to keep up on.However as stated above there would be a cut in the hi rpm power.
Old Feb 3, 2002 | 04:32 PM
Kadafiy's Avatar
My friend has one of those 2 into 1 carb setups that he would sell you. It's the whole kit from Trinity and was hardly used. PM me if you're interested.
Old Feb 3, 2002 | 10:08 PM
2hard2holdon's Avatar
i've ran the trinity set up and it does aid low end power and i feel that it really doesn't hurt top end but it also doesn't help it ends up about the same.If you decide to run it stay with the stock air box with the prodesign foam filter as it will give you better low end than just a clamp on k-n-n.As far as jetting it's one carb instead of two so it turns out to be less of a mess.good luck
Old Feb 9, 2002 | 11:38 AM
SaMs0n's Avatar
I'm thinking of getting a 2 into 1 carb setup as well for XC racing. Who else besides Trinity makes them? I heard graydon makes them too I think?
Old Feb 9, 2002 | 01:01 PM
Kadafiy's Avatar
I'm selling the trinity kit for my friend. He wants $200 for the whole kit except throttle cable. The kit has a backing plate, carb, and k&n filter with filter skin.
Old Feb 9, 2002 | 01:29 PM
SaMs0n's Avatar
which carb is on that Kadafiy? and does it hook up to the stock airbox?
Old Feb 9, 2002 | 01:33 PM
Kadafiy's Avatar
I think it's the Air Striker and no.
Old Sep 16, 2002 | 02:03 AM
atvracer557's Avatar
Kadafiy
your friend still have the kit ??
