Mixing alcohol 2 stroke
Old Oct 26, 2002 | 10:48 PM
vilnrk's Avatar
Default Mixing alcohol 2 stroke
What ratio do you mix your oil and alcohol to?
I mix mine at 20:1
I wonder if it is nesessary to run it this rich on oil
Old Oct 27, 2002 | 08:52 AM
gaff's Avatar
Do a search on methanol here in this forum, or just look down a few threads for the one titled Methanol?????.
I just did a project on methanol and a few guys came in there with some very good info. I believe you'll find every thing your looking for there.
Old Oct 27, 2002 | 01:18 PM
raptorboy673's Avatar
on the klotz bottle it says between 32:1 and 50:1 chad and johnny have been experimenting betwween those numbers and 50:1 works good the way they are jetted.
but if it will slow that stinkin r down you need to mix it 5:1. he-he
Old Oct 27, 2002 | 01:27 PM
vilnrk's Avatar
raptorboy673 - i was going to mix up 5 gallons at 40:1 and try it today, the weather is not looking to good tho. really thick mist in the air, i hope it goes away.
how do you like the tires? i never got to use them are they any good?
turbo bob
Old Oct 28, 2002 | 02:46 PM
AlkyBurninX's Avatar
HOLD UP! 32, 40, 50:1 with alky?!!! And people wonder why they melt pistons and blame it on methanol. If you are running alcohol with Klotz Benol, I would suggest a 24:1 mix. Alky doesn't have any lubricating ability in itself like gas does. This is one of many reasons you should mix rich.
Old Oct 28, 2002 | 08:13 PM
the alky we buy has top end lube in it also, might effect it some
exmotocrosser
Sep 13, 2019 06:12 AM
exmotocrosser
Sep 26, 2015 08:18 AM
BYC
Sep 25, 2015 02:10 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
