Dyno-Port vs. Moto-Fast pipes for Banshee...
YOU CAN NOT BEAT THE MOTO-FAST PIPE. I know its bold to say this but I've been using mine for about two years and its the most awesome pipe i've ever had. Low power is greatly improved and through the mid range. This is the only thing i've done to improve my 98 Banshee and everwhere I go people are asking me if something is wrong with the bike or if I'm running alcohol or just where's the rest of your pipe? You will fall in love with sound. You dont hear two pipes sounding off but instead what you hear sounds like air passing through your silencer. I have the SS and in two years it has hung very tough and has no discoloration at all anywhere. I do however recomend getting an aluminum exhaust clamp because the stock clamps dont last long on the bigger size connection.
Sandstorm,
How do you do going against banshees with FMF's, T5's, pro-circuit's, or other mid to high end pipes? I understand the moto-fast will get the jump on them but can it keep the lead? I figured it's a matter of a gear or two before they pass you by and end up a quad length or two in front by the time you wind out 6th. Which is ok, because the moto-fast was designed to be a low end pipe. I was just curious how it did next to one of the other pipes.
Rob
96 Banshee
Rob
96 Banshee
Normally drag racing in Silver Lake, a T5 or FmF Fatty bike will catch you at the top of third or shifting into fourth, however it is also up to the rider. Once you learn to shift you will win a lot of those races. And yes, you will sound better than anything out there!!! Just my experiences. Dave
#15
i have the moto-fast pipe on my 250r with carb dg silencer and vented air box with bandits it will break the tires lose on pavement (or if you arn't up on the seat one quick flip) i never used a nother pipe other than stock with stock silencer but it is a lot faster than stock.
#17
For Dyno-port pipes www.dynoport.com
For Moto-fast pipes www.moto-fast.com
Probably going to have a good wait from the folks at motofast and I hear dyno is getting back up now as well....
mrtidy
Feb 3, 2016 05:00 PM
ltzbrad
Sep 25, 2015 05:52 PM
greg86hd
Sep 16, 2015 12:32 AM
