Race mods for Mojave
Old Apr 16, 2000 | 04:48 PM
Mxracer98's Avatar
WHat are some goods engine mods to the mojave except tires,air filter,and pipe. Does anyone make a higher compression piston for the mojave except 11:5:1?
Old Apr 16, 2000 | 10:26 PM
JD250R's Avatar
I own two Mojaves. One has just a pipe and different gearing while the other has a lot of stuff. I have the Wiseco 11.5:1 ceramic coated piston, White Bros. cams, KLR250 blackbox, 13/41 gearing, ATC350x rear shock and Works fronts, Dura-Blue axle, Razrs, 36mm Kehuin 250x carb and throttle, port and polish, uni pod filter, prm baja bumpers and skids, team Green plastic, and a Cobra JET pipe. This thang hauls. If I were you the first thing I would do is get better shocks and a Dura-Blue +2 axle. You have have all the power in the world but it won't do you any good unless you have a good suspension. The Wiseco 11.5:1 piston is the best your going to find unless you what to run expensive race gas.
JD250R's Avatar
I own two Mojaves. One has just a pipe and different gearing while the other has a lot of stuff. I have the Wiseco 11.5:1 ceramic coated piston, White Bros. cams, KLR250 blackbox, 13/41 gearing, ATC350x rear shock and Works fronts, Dura-Blue axle, Razrs, 36mm Kehuin 250x carb and throttle, port and polish, uni pod filter, prm baja bumpers and skids, team Green plastic, and a Cobra JET pipe. This thang hauls. If I were you the first thing I would do is get better shocks and a Dura-Blue +2 axle. You can have all the power in the world but it won't do you any good unless you have a good suspension. The Wiseco 11.5:1 piston is the best your going to find unless you what to run expensive race gas.
Customer Service #1
May 15, 2020 08:46 AM
Robinhood
Dec 26, 2015 10:28 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
Sep 23, 2015 06:23 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
