04 Polaris Sportsman fires only once
Welcome to the forum! Get the kit! DO NOT,I REPEAT, DO NOT let the dealer con you in buying left over Ducati ignition parts!! Let him try to pawn them off on someone else! The controller may work for awhile,but then the stators fry also,then you're stuck!! I was dizzy for awhile replacing both of em(at the customers expense) until the Kokusan kit came along and solved the problem! Should have been a recall I know,but wasn't! You might pass this on to the dealer about how much they fail(which if he's smart,he already knows!),but Polaris won't reimburse him and he's going to get rid of it one way or another to at least get his money back! Good luck! OPT
i have the kokusan ignition on my polaris 700 and it seems to be running extremly hot ...... i cant keep my leg on the side of bike due to the heat coming from exhaust and i burned through almost a tank of gas in a few hours just riding dry dirt trails no mudding .... can someone please help me figure out whats going on with my bike
#15
Not necessary to post in the regular section and the expert section on the same problem.https://atvconnection.com/forums/pol...cate-post.html
bzdok1234
30
02-23-2016 01:55 PM
