2004 polaris predator????
Old Jun 13, 2011 | 02:28 PM
ripper72's Avatar
Default 2004 polaris predator????
ok i have about about 400$ and i want to make my preddy 500 have less speed and more power or just same speed more power what mods should i get and where could i get them so if you could help me it would be greatly appreciated
Old Jun 13, 2011 | 02:31 PM
ripper72's Avatar
is this kit bad Quadworks Stage 2 Power Kit - ATV - Motorcycle Superstore
Old Jun 13, 2011 | 03:24 PM
Have you checked into just replacing the rear or front sprockets if aftermarket ones are available??
Dropping a tooth on the front sprocket or going a couple or three teeth larger on the rear will give you more "grunt' without a huge loss in speed! Just a thought! OPT
Old Jun 13, 2011 | 03:36 PM
ripper72's Avatar
ok that sounds like it should be good but i read somewhere that they might not fit without having to trim something
Old Jun 14, 2011 | 10:14 PM
YFZ660R's Avatar
To ATV Thieves: "Hope you guys flip and die douches!"
A full exhaust system along with a good aftermarket filter are the most common bolt-ons to open up response all through the power-band, and that's what I recommend to you. This will let your engine breath better and release gases more efficiently. But don't forget to re-jet to get that right fuel-to-air ratio. Other than that, you can always go down a tooth on your front sprocket to gain a bit of acceleration down low, this will also steal from your top end though.
All in all, there's many exhaust brands out there, just do your research. Another thing is you might wanna save up just a bit more.
Old Jun 15, 2011 | 07:02 AM
Jmuddin284's Avatar
If you ride anywhere that is atleast a little dusty or muddy you won't like how often you'll have to clean that k&n filter, even with a pre-filter on it. Unless this setup goes in the airbox somehow. I'm going to UNI for two reasons, first being ease and cost of cleaning and second being the price difference. I still run k&n in all my street stuff, but never again in my 4wheelers
Old Jun 15, 2011 | 10:30 AM
Finally found someone who shares my feeling on the K&N and dirt! I still believe they are good for the street,but UNI is best at trapping dirt and sand. Every off road KTM,Husky,or Husaberg we sold had an oiled foam filter whether it was a 2-stroke or 4 stroke,same for most other off road brands. I've seen the damage that can happen with the K&N. An atv shares the same dirt,sand and mud as a dirt bike.PLUS I never even liked the paper element filter even with the sleeve that Polaris has provided on all the atvs. An Uni is a more logical choice to protect the engine. BUT I'm sure I will get protests on this from K&N users who will swear by them! I even have an UNI in my old Honda Nighthawk! OPT
Old Jun 15, 2011 | 09:43 PM
Jmuddin284's Avatar
Like any good lesson learned, it has to be learned the hard way. Like I said before, I will continue to use K&N in all my onroad vehicles and my mud truck and jeep too. But with the drought we've had in Florida there is nowhere that isn't EXTREMELY dusty, that's how I learned my lesson about using one on my 4wheeler. I even had a pre-filter and after EVERY ride no matter if it's just a couple hours near the house or an all day event, I would have to spend time taking the filter off, cleaning it, waiting for it to dry, oil, re-oil the spots that didn't take on the first go-round, then put the pre-filter back on and reinstall it. That SUCKS. I know the UNI will have somewhat the same process, but a buddy of mine has a uni and can go several rides before he has to wash his out and re-oil. Even then it's just preventative maintinance because his still isn't half as bad as my K&N gets after one ride. I highly doubt that even the ones that go in the airbox would last much longer than a clamp-on, unless you live somewhere that it rains in the off chance that it's not snowing all the time
1966F100
Jul 14, 2015 12:19 PM
Gtsordo
Jul 13, 2015 10:38 PM
1966F100
Jul 12, 2015 03:08 AM
steveo612
Jul 11, 2015 08:35 AM
jettman
Jul 6, 2015 12:16 PM
