1996 scrambler 400
Old Aug 6, 2011 | 08:33 PM
jakerman's Avatar
Default 1996 scrambler 400
Hi there Again!
two probs...
the darn chain keeps coming lose and even came off the other day. I adjust it with twisting the rear carrier like you should but the chain comes lose after riding.
and the hubs on the wheeler.
i saw on the forum that type f tranny fluid is okay, how much to use?
and i guess one more thing
should there be lubricant in the gear shift forward nuetral and reverse box...
thx as usual
james
Old Aug 6, 2011 | 11:38 PM
If chain keeps getting slack after adjusting,either the eccentric is loosening up(not tightening enough) OR if the chain is an older chain,might be time to replace it! Just grab the chain and if you can wiggle it sideways in several places then the chain is worn out and will not keep tight. Another way to check is to tighten the chain,roll the machine and see if chain raises and lowers(high and low spots) and is tight then loose. Use Polaris Demand Drive Plus hub fluid in hubs,Type F was used back in 1986-1988 but can be used in a "pinch" until you get the right fluid. 30 wt oil is sufficient in the shift box, Fill to where the oil barely cover shift levers,DON"T over fill! OPT
Old Aug 7, 2011 | 11:05 AM
jakerman's Avatar
Default thanks
awesome...thanks for the advice.
the black box that is attached to the gear selector handle is that right? (F N R) assuming
Old Aug 7, 2011 | 12:02 PM
SORRY on the shifter!! Thinking of the other models that are fluid filled!! Your shifter just has plastic collar bearings and there is no fluid. The transmission(gear case) takes Polaris AGL fluid,need to change annually. OPT
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Nosparkpolaris
Sep 20, 2015 04:21 PM
chewy78
Sep 8, 2015 10:37 AM
