Engine Swap
Old Oct 31, 2011 | 08:45 PM
texashogdogs's Avatar
Default Engine Swap
Hello,
I got a 1994 Polaris 400l two stroke wheeler . I also have a 1997 Polaris 425 magnum engine four stroke and I was wanting to know if the 425 magnum motor will bolt up on the 1994 Polaris 400l two stroke frame ?
Doing a engine swap . Anyway thanks .
Old Oct 31, 2011 | 09:02 PM
Welcome to the forum. Motor mounts are different, you would have to modify these and weld a tab for the 425 on the right side of the frame,I believe also the transmission and linkages would have to be swapped? Plus you would have to swap electrical harnesses,etc. LOT of work,but others on the forum have done even more radical swaps. I'm sure you will get more responses! OPT
bzdok1234
30
Feb 23, 2016 01:55 PM
toonces
Jul 28, 2015 01:58 PM
tweeder
Jul 5, 2015 01:57 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
