hand warmers kit hook up Polaris Scrambler 500
Old Nov 23, 2011 | 06:49 PM
Suzuki_Help!!'s Avatar
Default hand warmers kit hook up Polaris Scrambler 500
Hey I have a 1999 Polaris Scrambler 500 and I am wanting to put an SPX grip and thumb warmer kit on it. The instructions say to hook the positive wire to the key switch but I don't see anywhere to put it. So I am going to hook it up to the battery. I think this will be okay but I just have to remember to turn of the hand warmers. Also I don't know where the ground is down near the battery. Can I just drill a hole into the frame or will this ruin the infer structure. If someone knows where to hook up the positive wire near the key switch that would be great because there is a ground near there. I know this sounds a little confusing. But any help is greatly appreciated.
Thanks
Old Nov 23, 2011 | 07:06 PM
Just hook it to ANY red/white wire under the front panel, red/white wires powered up only when the switch is on!Ground to any brown wire also. You can put a simple toggle switch inline with the red/white wire(if kit doesn't provide an on /off switch) and mount on the the front panel or wherever if you wish and won't matter if you forget to turn it off,the ignition switch will take care of that! That's how we hooked em up. I wouldn't hook directly to the battery! OPT
Old Nov 23, 2011 | 07:54 PM
Kerbbirds's Avatar
ditto on hooking to red -white that turns on and off with key, should be an empty one covered in plastic under front panel
Old Nov 24, 2011 | 06:25 PM
Can I hook the power wire to the red and white wire that goes to the temperature light on the control panel? I don't see any plain red wire. The is a bunch of wires going to the ignition switch but they are covered in a plastic wrap. Do I take that little plastic cover off where those wires go into the ignition. And if there is a red wire there how do I hook it up inside the plastic cover? Do you guts mean red and white wire. Or just a plain red or white wire? I don't really know what I'm doing. By the way the hand warmers come with a switch.
Old Nov 24, 2011 | 07:42 PM
user493's Avatar
Moto Psycho
Just find a red wire that has a white stripe.
Cole Hadden
Jun 15, 2025 09:05 AM
maxjung
Jul 14, 2015 03:10 AM
maxjung
Jul 13, 2015 05:11 PM
toonces
Jul 11, 2015 12:01 PM
Chocobamofo
Jul 10, 2015 07:46 PM
