2007 Sportsman 500 h.o gas Guage
Old Jun 7, 2012 | 01:58 PM
KING4X4's Avatar
Default 2007 Sportsman 500 h.o gas Guage
As of know its has full tank and only has 2 bars on ! What the fix here? Thanks!
Old Jun 7, 2012 | 04:44 PM
Could possibly be the float arm rubbing against the tank(fixed a few of those by bending the arm out a little) or fuel sender corrosion,plus if you look at the tank and the deep drop it makes I don't think I've ever seen one exactly accurate. OPT
Old Jun 7, 2012 | 07:13 PM
KING4X4's Avatar
Thanks how do get ahold of the float arm?
Old Jun 7, 2012 | 11:10 PM
You have to remove the sender from the tank and slightly bend the wire arm to where the float won't rub the inside wall of the tank. While you have it out you can do an ohms check with a meter to see if ohms vary from empty position to full to see if the sender is working properly. OPT
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
tropicalnuts
Aug 22, 2015 01:15 PM
readymixer169
Aug 21, 2015 10:05 AM
Sjrpp
Jul 5, 2015 09:04 PM
