How to tell if springs are bad
Old Jul 27, 2012 | 11:41 AM
94-400l's Avatar
Default How to tell if springs are bad
I have a 94 400l 4x4 with a saggy front end problem. I put in 1 1/2" spacers and it helped but the struts are hitting on the top of the stroke. After this happened I am planning on replacing the struts and see if that will correct my front end issue. The struts I can push them in pretty easyily and they come back about about 1/2 way .
Now to my question: How do I know if I need to change the spring also?
cost is 131.90 for just struts or spings/struts together are 233.90 from Snowmobile Parts, Accessories, Clothing | Hi-Performance Engineering
Thanks
Old Jul 27, 2012 | 04:18 PM
First off you'll get much better strut cartridges with the updated capped off # 7041451 cartridge that replaces the old ones(# 7041304) that it has now. These were bad about leaking oil after only a couple years on some atvs. Try the new strut cartridges first and see if the front end is stiff enough for you. You can always add the spacers or new springs if it isn't OPT
Old Jul 31, 2012 | 08:21 AM
94-400l's Avatar
Thanks OPT..........I went ahead and ordered the springs/struts combo made by Bronco
Polaris ATV Struts | Front Gas Struts | ATV Struts
They will be here tomorrow BUT I won't get a chance to install them untill next week.
Old Aug 29, 2012 | 07:32 AM
94-400l's Avatar
Smile
I can post now !! The springs/struts did the trick. Feels 100% better and is not botoming out now. Money well spent
shimanok2
Jan 29, 2016 07:37 PM
brinkkl2000
Oct 16, 2015 11:08 AM
chuck1177
Aug 11, 2015 03:22 PM
Wnthunting
Jul 9, 2015 03:02 PM
Mphillips
Jul 2, 2015 07:20 PM
