2004 700twin starting problem
Old Oct 6, 2012 | 07:18 PM
pa 5-0's Avatar
Default 2004 700twin starting problem
Hello. I am a new member in need of professional advice. I have a 2004 Sportsman 700twin that WAS in really pristine shape(500 miles). Unfortunately, my buddy rolled it off the side of a mountain and it tumbled about 300 feet. For the most part, my girl held up incredibly well and was running while laying upside down after the tumble. Speedometer was smashed, footwell crushed. I replaced the speedo. I have the fuel gauge on the speedo.
Bike will not start now. Lights up, turns over, will not run. Appears to my untrained eye that the bike is not getting fuel and/or spark.
Note: there is a small metal cube(selonoid??) with a metal plate that bolts on to the positive battery terminal with the cable. A small red wire comes off the cube and goes down toward the engine. The metal plate that enables it to bolt on to the postive terminal is broken so it is essentially disconnected. Dont know if this is a problem or not. Any help would be greatly appreciated.
I thank you in advance for any assistance.
Old Oct 6, 2012 | 10:45 PM
Welcome! If the engine turns over then the solenoid is still good. Pull one of the plugs and check if you do have spark by grounding the plug at the engine block. You can at least eliminate this as a problem if you have spark. Carb model or Efi? If an efi system you need a fuel pressure gauge to see if the pump is holding 39 psi,plus you should hear the pump prime up when the key is tuned on. If it's a carb model just pull the fuel line off at the carb and crank the engine over to see if you have fuel flow. OPT
Old Oct 7, 2012 | 05:59 PM
pa 5-0's Avatar
Thx for the reply sir. Bike is an EFI model. I went back out last night and hit the throttle lever while it was turning over. Bike did start. Never had to do this before. Bike always fired on half a compression even if it sat for a couple months.
While it was running last night, idle felt a touch rough but it did run unaided. I let it run for about ten minutes, revved it a couple times to warm it up. When I shut it off, it still will not start unless I hit the throttle lever.
Greatly appreciate your help.
Old Oct 7, 2012 | 06:04 PM
Check the thumb throttle slack. Must be between 1/16"- 1/8" slack only or the internal etc contact points will touch and not allow it to start without giving some throttle. Adjuster is just past the throttle housing. Falling down a cliff may have messed things up a little OPT
neilbedwell
Nov 10, 2018 11:02 AM
Land_shark1
Jul 10, 2015 12:53 AM
generalpops
Jun 5, 2015 08:23 PM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
