1997 trailboss 250 top end
Old Dec 16, 2012 | 10:58 PM
99veesixxer's Avatar
thanks OPT!! so im pretty happy now! lol, who do i send crank to? a machine shop? what do i tell them i need done? ( cause i have no clue lol) i need a new top end a carb rebuld and imma send crank off. get new bearings blah blaj blah.
Old Dec 16, 2012 | 11:07 PM
ok so if the crankcase is rusted what do i do with that??
Old Dec 17, 2012 | 07:05 AM
Cases can be cleaned up. The dealer or machine shop can clean up the crank shaft and install the rod. Just call around for prices OR you can send it to Ritter Cycle Racing - FAST, NOT FICTION. or numerous online sites if you don't have anyone local.I have had cranks rusted solid,cases in just as bad condition,but was able to get em running.If you don't have a manual get one! Doesn't matter what year model on the 250 manual as the internal mechanics are the same. OPT
Old Dec 17, 2012 | 11:22 AM
my mechanic is putting in the rod and crap for me. i dont have time but he has no job right now so were helpin eachother out, but i need to send the crank and the crank case to a machine shop and they will know what needs to be done?? do i just tell them to clean it?? or what??
Old Dec 18, 2012 | 12:50 AM
  #15
crank and crankcase arent as bad as thought, has gas full in crankcase, but crank has very little rust in a few areas imma make it work as is with a carb rebuild and a topend
Old Dec 18, 2012 | 11:58 AM
  #16
If rod has ANY up and down play on the crank(side to side is ok) the engine wont last with just a top end! Also make sure you roll the rod around and if any bearings feel rough they need to be replaced. Just trying to save you some $$ if the rod or crank bearings go out. They can take a new top end out with it! OPT
68_327_c20
Nov 25, 2023 12:26 PM
2quiker
Mar 22, 2022 08:36 PM
lgardner61980
Sep 20, 2015 01:32 PM
Myronh
Sep 8, 2015 11:27 AM
