'96 Sportsman 500 Not firing?
Old Sep 11, 2013 | 09:34 AM
Axton's Avatar
Default '96 Sportsman 500 Not firing?
There's gas, the flow switch is set to "ON", Bendix is engaging and turning the flywheel. It just won't fire...
Brand new Bendix, Brand new Spark Plug, brand new flywheel, brand new key switch, brand new starter, etc.
(Carburetor looks like it's in great shape, but i probably should clean it.)
To Old Polaris Tech, i can't buy a carburetor rebuild kit at the moment. (Money issues)
Old Sep 11, 2013 | 10:15 AM
Make sure you have spark first if you haven't already done so.Pull the fuel line from the carb and see if you have good fuel flow. If you don't it could be fuel pump related. If you do have fuel,then at least you can clean the carb jets,try to clean the float needle if needed and then see if it runs..
Old Sep 11, 2013 | 10:17 AM
Axton's Avatar
Ok, i will do that. Thanks, OPT for helping me so much.
I pulled the hose and it had a great fuel flow.
Will clean carburetor and post back what happens!
Old Sep 11, 2013 | 12:12 PM
Axton's Avatar
Ah, the fourwheeler cranked right up. It does indeed have a knocking noise.
Gonna call the guy and discuss what we can do.
Jmuddin284
Jan 19, 2026 07:16 AM
Cole Hadden
Jun 15, 2025 09:05 AM
COFatboy
May 2, 2020 12:06 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
toonces
Jul 24, 2015 09:03 AM
