2005 polaris Phoenix trans help needed...please
#21
I was aware that there is a clip cause I have a repair manual and you have to remove the collar and the clip is under it. According to what I had researched online the collar was supposed to slide right off. After I got mine collar off of the shaft by (unfortunately) damaging the shaft I could then access the clip and remove it. Hopefully the dealer u took it to will have better luck than I did.
#23
Hi every1, I got a Phoenix 200 for my wife and she rode it for 20 minutes and then I took it in the woods for 15 minutes and tore it up. Had to back all the way back out of the woods cause it was stuck in reverse. To make a long story short, she is pppppppi$$ed off. Now I have the tranny apart and have bought a new shift fork and shift ratchet but I can't seem to figure out how to get the gears off to change the shift ratchet, I don't c any.kind of clip holding the gear on but the repair manual says remove the circlip I'm so confused, I'm gonna b in the doghouse if I don't get it fixed for her. Any ideas would be appreciated. Thanks
#24
#25
2 CC Phoenix 200cc if you get get a ball bearing puller and release the clip it will pull the gear of to get set a shift shaft into please
