Ticking Valve Adjustment
Old Sep 30, 2013 | 08:28 PM
Axton's Avatar
Default Ticking Valve Adjustment
Hey OPT,
I adjusted my valves and realized that everytime i adjust the space according to the .15 mm feeler gauge and take it out, the top of the valve pusher or rocker or whatever falls down and makes a *tick* noise. Is it supposed to stay up or fall down?
Old Sep 30, 2013 | 08:53 PM
Make sure you're at TDC with the cam index pin straight up and lobes will be down! Use two feeler gauges on the exhaust rocker arm so it won't be cocked. With the feller gauge inserted and valves adjusted to .006(.15mm) there should be a slight drag on the feeler gauge. YES,there will be a little up and down play on the rocker arms,but when you reinsert the gauge it still should have a drag to it.
Attached Thumbnails Ticking Valve Adjustment-2011-05-21_125845_00_polaris_500_cam_timing.jpg
Old Sep 30, 2013 | 09:04 PM
Axton's Avatar
Ok, well, i put everything back together. Cranked it up, and it's quieter, but still has a ticking noise. :/
donintennessee
Jan 8, 2021 12:40 PM
Hankey Pankey
May 1, 2018 01:33 PM
fordfaithful21
Dec 7, 2015 05:52 PM
Hankey Pankey
Aug 17, 2015 05:01 PM
MNatv89
Jul 7, 2015 11:36 AM
