Problem with front cv boot
Old Jul 6, 2014 | 11:55 PM
vanick's Avatar
Default Problem with front cv boot
Can anyone explain what all has to be done to change a front cv boot or a website to go to see how its done Thanx
Old Jul 7, 2014 | 08:47 AM
Manual is the best,but plenty of videos on youtube that can help. Whether it's the inner or outer boot,you have to drop the a-arm,brake caliper,tie rod and pull the strut out enough to wiggle the shaft out. If it's the inner boot,either remove the clevis pin on the older models or just jerk on the shaft on the newer ones to remove the shaft from the differential. If it's the outer boot(by the hub) just unsnap the bands,push the boot back,use a brass or dead blow hammer to knock the cv joint off the shaft. It's held in place by a circlip. Then you can clean up/grease the cv,slip the new boot on,grease it,replace the clamps and re insert the shaft in the strut.
Old Jul 7, 2014 | 08:48 AM
TLC's Avatar
TLC
Its a Arctic Cat but there all done the same.
Old Jul 7, 2014 | 09:17 AM
Main thing to have if you do your own boots is the right cv band pliers. Less fighting the clamps and makes the job a snap. We kept a good supply of bands for people that tried to use needle nose pliers,etc and kept destroying them. Good tool to keep in your tool box.Available at any auto supply. Lisle LIS30500 CV Boot Clamp Pliers for Earless-Type Clamps | CV Joint, Axle, Hub Tools
Old Jul 7, 2014 | 04:03 PM
vanick's Avatar
Thanx for the info and I will also check out the videos.
tycobb
ATC 3-Wheelers
Oct 23, 2015 07:37 PM
VRRRRT
Jun 27, 2015 09:38 AM
Rooky
10
Jun 23, 2015 09:35 PM
DOAinNY
Jun 11, 2015 10:34 PM
