88 Trailboss 250 agony - seeking help from OPT
Old Jun 14, 2015 | 05:13 PM
  #31
Good deal! Makes a difference when someone knows what they're doing on cylinder boring.Hope you get years of service out of it.
Old Jul 9, 2015 | 07:07 AM
  #32
ddiggerr's Avatar
Well I am back where I started again. Not starting and exhaust and case filling with fuel.
I am thinking it might be the stator. I checked for spark and it doesn't appear to be all that strong. This leads me to believe that this is why it is not firing.
My compression is still approx. 120
I have checked manual to test resistance but can only find the numbers for the charging coil. I cannot find anything on testing the exiter coil.
Does anyone have the correct resistance for testing this?
Thanks
Old Jul 9, 2015 | 07:47 AM
  #33
Black/Red to Brown/White should ohm out around 120 ohms (+/- 20%) Don't forget to check the coil tab to ground(.3) ohms,plus the secondary,coil wire to tab 6.3k ohms. Plug cap around 4.8k ohms or so(5k ohm cap) Plus any breaks in the plug wire itself.
Old Jul 9, 2015 | 08:35 PM
  #34
ddiggerr's Avatar
Well I have 122
Coil tab to ground is .7
Plug to ground is 11
Old Jul 10, 2015 | 06:32 AM
  #35
Originally Posted by ddiggerr
Well I have 122
Doesn't sound like the stator. Coil tab to ground past limit,plus test should be bare coil wire to coil tab(6.3k) Either way sounds like the ignition coil is weak. Plus make sure you check the plug cap. Many people over look it as a problem. No test on the cdi,so if you want to change the coil out first and see what you have. Plus in a weak spark condition,a dirty flywheel or stator itself can cause this. Plenty of cheap 10 buck coils around if you want to try this first.http://www.ebay.com/itm/IGNITION-COIL-POLARIS-TRAIL-BOSS-250-ATV-QUAD-88-90-91-92-93-94-95-96-97-98-99-/190798124421?hash=item2c6c745585&vxp=mtr
Old Jul 10, 2015 | 04:42 PM
  #36
ddiggerr's Avatar
Doesn't sound like the stator. Coil tab to ground past limit,plus test should be bare coil wire to coil tab(6.3k) Either way sounds like the ignition coil is weak. Plus make sure you check the plug cap. Many people over look it as a problem. No test on the cdi,so if you want to change the coil out first and see what you have. Plus in a weak spark condition,a dirty flywheel or stator itself can cause this. Plenty of cheap 10 buck coils around if you want to try this first.Ignition Coil Polaris Trail Boss 250 ATV Quad 88 90 91 92 93 94 95 96 97 98 99 | eBay
Boy do I feel like a dope. Yes I overlooked the plug cap. It was loose.
Tightened it up and now everything is within spec. Fired up
Sitting now to see if it will start back up in a few hours
Old Jul 10, 2015 | 05:43 PM
  #37
There's a term for this... It's called over looking the forest because all the blame trees are in the way..
68_327_c20
Nov 25, 2023 12:26 PM
Jason Poulin
Sep 20, 2015 02:49 AM
Myronh
Sep 8, 2015 11:27 AM
vinrum
Aug 22, 2015 10:38 AM
binky79
Jul 30, 2015 06:37 PM
