Trail Boss 250 & Explorer 300
Old Dec 14, 2014 | 12:47 PM
johnjones's Avatar
Default Trail Boss 250 & Explorer 300
I have a Polaris Trail Boss and Explorer but don't know what years they are. I have found some numbers on the Explorer plastic intake. Numbers are 6/19/96 & 5131006-03 Is this the year Model. Nothing on the frame.
Tailboss has 1 number on the frame its *1467333* does anybody know what this is?
Old Dec 14, 2014 | 01:16 PM
On these older models look on the right frame down tune. Should show a "W94-96",etc. This is the model year. If you still have the engine serial number on the recoil,first two digits is the year model also.
Old Dec 14, 2014 | 01:20 PM
johnjones's Avatar
I have 2 serial numbers on this model. It says 96 on the coil tag and 99 on the tag below the shifter.
Old Dec 14, 2014 | 01:34 PM
If you still have number on the engine,should look like this. Plus newer model 17 digit vin#'s are are on the driver side lower frame behind the a-arm.
Old Dec 14, 2014 | 01:52 PM
johnjones's Avatar
Ok I have looked all over the 250 and can't find anything. I will look over it again. The 300 had 2 stickers on it one on the coil cover and it said 96 and sticker below the shifter said 99. The engraved number on the A frame said 09/03/96 I think.
Old Dec 14, 2014 | 02:03 PM
Probably a 96,as far as the shift box it may have been a replacement. Couple different vin decoder sites,don't know if they'll help,seems the old Polaris site is down. VIN View /// AnalogX VIN Decoded: 4XAXH76A8AD092394
Old Dec 14, 2014 | 02:10 PM
johnjones's Avatar
I will go with a 96 on the Explorer. Don't know what to do with the Trail Boss. Don't know if it's so old it didn't have a VIN. Trying to figure out which Haynes manuel to order
Old Dec 14, 2014 | 02:12 PM
johnjones's Avatar
The Explorer has a fan up front but nothing behind it so I guess I gotta get a blower. The Boss has no fan,how is it cooled?
Old Dec 14, 2014 | 02:52 PM
Explorer 300 is a dry sump engine with remote oil tank. Why it really needed a fan I don't know as most times the fans would hardly kick on.Fan sensor is on the rear engine mount and not on the engine. Has to get super hot for a fan to kick on. Not needed in my opinion. 250 is similar to the 300,but is air cooled only.Plus a lot of times these sensors broke from vibration.Better imo if you want the fan,just wire it up to a toggle switch. Item#13 is the sensor for the fan.Dirt Cheap Yamaha & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
Old Dec 14, 2014 | 03:19 PM
johnjones's Avatar
Thanks for the help. Don't think I will worry about the fan. I got these 2 atv for my kids for Christmas. They won't be riding them for hours and over heating. Do you think the Haynes manuel is the best book. I don't know much about this and was going to get it and have a project with the boys.
