someone reffered me to opt! 96 Polaris magnum 425 4x4 starting trouble
Old Aug 26, 2015 | 11:21 AM
Pull the front panel,trace the wiring from the ignition switch as it ties into the main harness. Same for the left hand control switch. If you turned the bars and it shut off, possible you have a short in this area causing all the problems. Under the steering post area is where all the twisting,turning and stress on wiring and connectors happen where they tie into the main harness.
Old Aug 27, 2015 | 09:29 AM
mattcraig1's Avatar
hooray we did it! it was a not properly grounded solenoid and than when we rewired the new one at first it also wasnt grounded. had to clean off the battery case and tighted everything up! now the fun part, trying to fix brakes that have been locked up for years!
Old Aug 27, 2015 | 12:23 PM
Glad it was something simple.
Big600twin
14
Jun 16, 2015 09:30 AM
Sgtshultzy
Feb 19, 2003 07:04 PM
Muddog1
Jan 5, 2001 08:22 PM
mattlvsbball
Apr 24, 2000 06:54 PM
atving
Nov 17, 1999 09:24 PM
