Predator 90 rear wheel wobble
Old Mar 22, 2016 | 06:28 PM
  #31
Some of these after market kits use this under the bottom compression ring. Supposed to keep the ring from sicking,but to me not needed.. Here's some one that had the same thing."I received a piston and ring kit for my 50cc 2 stroke and it also had one of the wavy rings. I contacted the supplier (autotech 355) and they told me that it goes in the bottom ring grove before the standard type compression ring . They said that it increases the tension on that ring to improve compression. I used the wavy ring and so far everything is fine." OR so he said..
Old Mar 22, 2016 | 06:31 PM
  #32
rdjustham's Avatar
Ok so i went and looked, and i guess if its aftermarket the bike has had a rebuild done prior. I found that ring. sticking out of the exhaust "header" if you will. Guess i should skip that on install?
Old Mar 22, 2016 | 06:33 PM
  #33
My two cents worth yes,chunk it..
Old Mar 22, 2016 | 06:37 PM
  #34
rdjustham's Avatar
Ok thanks. If youre ever in south florida i owe you a beer! So far have hubs coming, new reeds, top end kit so it should be a totally different bike! Ohhhh... There was no exhasut gasket but cheap cycle parts shows one in the parts diagram. Should i grab one or is it not needed?
Old Mar 23, 2016 | 07:12 AM
  #35
Get a new one.The old ones usually get flattened and can leak..
Old Mar 26, 2016 | 09:46 AM
  #36
rdjustham's Avatar
Ok so the top end showed up today and i plan on assembling tonight. Quick question, the service manual says to run 50:1 in the tank on rebuild, however since i am not using the oil injection should i just run 36:1 even on the first tank or would you suggest a different mix?
Old Mar 26, 2016 | 10:13 AM
  #37
50:1 is what we premixed all the first tanks of new machines,youth and full size straight out of the crate. This was to assist the oil pumps in piston and rings breaking in in case of possible air pockets in oil pumps. If you're bypassing the pump, with good oil,36:1 is the most I'd go with these low compression 2 strokes. In comparison, 32:1 is what most of our Ktm racers went with with no major problems. Any major brand 2 stroke premix oil is ok.Just try to stay with one brand as some don't mix well with other brands or so some have said. Spectro,Silkolene,Amsoil,Maxima,Belray,etc. Some people even swear by Super tech oil from Walmart. Choice is yours.
Old Mar 26, 2016 | 10:59 AM
  #38
rdjustham's Avatar
Already picked up some of the Polaris VES two stroke oil, what mix would you suggest? Or should i get something different?
Old Mar 26, 2016 | 11:23 AM
  #39
Sled oil but plenty of people have used it in other type machines plus description says it's good for all 2 stroke engine applications. I'd still premix 36:1.We didn't stock any of it down here for obvious reasons.
Old Mar 26, 2016 | 11:41 AM
  #40
rdjustham's Avatar
I was kinda shoccked they have sled oil in south FLORIDA myself. lol OK 36:1 it is. let ya know how it goes. thanks for the help!!
