2001 Sportsman 500 HO No start
Old Mar 4, 2017 | 06:54 AM
  #31
Anti vibration bracket that helps keep the carb from shaking around and dumping fuel into the engine or air box. This could be some of the problem.Just get a bolt and nut that works,doesn't have to be the factory one.I'd still check the float adjustment.
Old Mar 4, 2017 | 06:55 AM
  #32
jeffreybandel's Avatar
OK. Thanks.
Old Mar 4, 2017 | 07:05 AM
  #33
I just checked the oil and it clearly has a lot of gas in it and the level is very high. I guess that makes sense because I have read that excess oil in the airbox can be a result of oil overfilling. Does that solidify I have a carb issue?
Old Mar 4, 2017 | 01:00 PM
  #34
Pretty well explains that you have a carb issue with gas contaminating the oil. You may have other problems but get this one fixed first as thinned out oil can cause engine damaged if left this way for too long.
Old Mar 4, 2017 | 01:11 PM
  #35
That float valve is a tricky little bugger. Kinda of hard to tell if I have it correct.
Old Mar 4, 2017 | 01:27 PM
  #36
Look at this article again on the BST40 carb. He goes into good detail how to set the float level correctly by bending the tab if needed.The BST-40 Bible | Adventure Rider
Old Mar 4, 2017 | 01:29 PM
  #37
I have looked at it a hundred times. To me it is a little confusing where the parallel lines meet relative to the position of the carb. It looks like they should be parallel when it is tilted slightly to the right (in his picture) but I'm not sure.
Old Mar 4, 2017 | 01:35 PM
  #38
Tilted with the float tab resting on the small pin on the float needle,NOT pressing it in.
Attached Thumbnails 2001 Sportsman 500 HO No start-2471649347_b2a1a773d6.jpg   2001 Sportsman 500 HO No start-2472338688_6fd5c697f3_o.jpg
Old Mar 4, 2017 | 01:40 PM
  #39
I think that is what I have. Need to go get more oil nd give it a shot.
Old Mar 4, 2017 | 03:18 PM
  #40
Got it back together and it is running with no oil or gas in the airbox. Mini success. Thanks for the direction.
It is idling really fast so it needs some adjustments. Is this something I should adjust on the handlebars or is the adjustment internal to the carb?
