Old scrambler wont start again....
Old Sep 15, 2016 | 03:45 PM
bigpollyboy's Avatar
Default Old scrambler wont start again....
1998 scrambler 400 4x4 intermitting starting problem.....runs fine then wont start. Remove red plastic hood and push down on the birds nest of wires and it fires right up...now the "wire push down" method doesn't work anymore (LOL) so I guess its time to fix it for real...any help/ideas would be much appreciated
Old Sep 15, 2016 | 04:20 PM
1ArmBandit's Avatar
find the broken wire..
Old Sep 15, 2016 | 05:46 PM
Can't add much more to that than the most common areas for shorts were from the left control switch wiring and ignition switch. Just a slow process if it's a short.
Old Sep 15, 2016 | 05:57 PM
user493's Avatar
Moto Psycho
Unplug each wire to see if the connectors are tight.
Old Sep 15, 2016 | 06:01 PM
Beat me to it jumbofrank.. Happened to think about the terminal board after I posted. Corroded terminals on the boaard could be the problem rather than a direct short.
Old Sep 15, 2016 | 06:17 PM
Thanks for the insight it is appreciated.......is there a way to clean the circuit board before hand. Can it be washed with water or is that a bad idea.
Old Sep 15, 2016 | 07:54 PM
1ArmBandit's Avatar
some fast dry electrical cleaner is what i use..pick it up at any auto store..
Old Sep 15, 2016 | 08:49 PM
user493's Avatar
Moto Psycho
When I bought some it was expensive but it's worth it. You can spray it in switches too.
dkerkman
Oct 4, 2016 11:15 AM
Robertr48
Sep 6, 2016 03:26 PM
Tim Bolle
Technical and How-To Articles
Sep 5, 2016 03:10 PM
pinchvalve
Aug 29, 2016 03:01 PM
Garrett Moore
Aug 27, 2016 07:27 AM
