Polaris xplorer 1996
First off have you tried the idle adjuster at the carb itself? Big knurled **** on the right hand side of the carb. Plus if the throttle cable is too tight adjusting the carb idle screw may not help. Play at the thumb lever should be around 1/16" or so. Cable adjuster is right off the throttle housing. Slide the rubber piece back,loosen the lock nut and turn the adjuster in or out as needed to get the correct play then tighten the lock nut.
badams340
29
09-28-2016 02:30 AM
sean_amadeus
09-24-2016 04:56 AM
