4x4 help
Old Dec 26, 2016 | 03:23 PM
bucky4433's Avatar
Default 4x4 help
Hello i have a polaris explorer 400 4x4 will not come on. I push in the button to engage but liht does not come on where should i start?
Old Dec 26, 2016 | 04:56 PM
Depending on model the gear shift switch may not be powering up the awd light.The bulb may even be burnt out but doesn't matter on this as it's just an indication that the awd is supposed engaged. Again it's usually the high $ switch in the shift box that's worn,not engaging the plunger.One way to bypass this is to open the front panel to get to the terminal board.Find the gray/white wire and move it to a red/white terminal which should allow you to have awd.
Old Dec 26, 2016 | 08:04 PM
bucky4433's Avatar
Thanks for the info its an 86 model i dont have many miles on the awd i will check it out. I read in another post to get all wheels of the ground and see if awd is working and bulb it just out. Thanks so much i will let you know what i find first trouble i have had with this machine they are as reliable as there snowmobiles which i have a few of them too
Old Dec 27, 2016 | 12:14 PM
86 didn't have an awd model.First ones out was in 87 and strictly mechanical in operation,no electrical involved.Check the right side of the frame down tube for a plate bearing the model and serial # to show what you have.1987 Polaris TRAIL BOSS 4X4 (W878027) Front Wheel Assembly | Cycle Parts Warehouse
Old Dec 28, 2016 | 09:24 PM
bucky4433's Avatar
hey jacked up all wheels awd works fine found bad bulb. Went to local dealer bulb is discontinued found some at another dealer have to call them and have them sent to me Thank you fro your help!
Old Dec 29, 2016 | 08:36 AM
Glad it's working. This little bulb is Nla from Polaris. Hard to find,don't know the source that Polaris used but glad you were able to find one. After 93 or 94 models the bulb didn't affect awd,was just an indicator that it was engaged.Mini bulb places should be able to have them,but haven't found a replacement yet for this small blue base twist bulb. MINIATURE/INDICATOR BULBS BY NUMBER, MINIATURE BULBS BY NUMBER, MINIATURE LIGHT BULBS BY NUMBER, MINIATURE LAMP BY NUMBER, MINIATURE LAMPS BY NUMBER, INDICATOR BULB, INDICATOR LIGHT BULBS, INDICATOR LAMPS, INDICATOR LIGHTS, MINIATURE LIGHT BULBS
