07 Polaris Sportsman 500 efi electrical??
Old Jan 19, 2017 | 05:28 PM
Vermontguy's Avatar
It's running a little funny and running 15 volts
Old Jan 19, 2017 | 06:38 PM
15 volts back to the battery? If so that is a little high if your meter is correct. That usually involves the high dollar command module. Item #11. Before you throw parts at it get this cheap manual and go through the electrical charging checks.2007 Polaris Sportsman 500 EFI Service Manual PDF Download
Old Jan 20, 2017 | 06:24 AM
Vermontguy's Avatar
they are running more test with Polaris today. Ill keep you posted. Boy is this getting old. this has been going on for 3 weeks I need to close this chapter in my life
Old Jan 24, 2017 | 11:53 AM
Vermontguy's Avatar
Wasent the IAC. Siad he and Polaris set all the sensors back to factory settings??? Not sure why they were not set at factory settings??/ Trying a new computer if its not that he is stumped. Ill pick it up and bring it somewhere else?
Old Jan 24, 2017 | 01:00 PM
  #15
Done gave my thoughts on your other post....
Old Jan 27, 2017 | 02:43 PM
  #16
Vermontguy's Avatar
Picked up my machine. The dealer said he doesn't know what is wrong with it. Suggested a whole new wiring harness!!!!!! I am going to go to another dealer next week. He said he had a lot of time in it but only charged me $100 since he didn't fix it.
Old Jan 27, 2017 | 02:49 PM
  #17
Very lucky to get away from these folks for 100 bucks +parts they threw at it. Find a good reputable shop and they should be able to find the problem.
Old Jan 30, 2017 | 06:19 AM
  #18
Vermontguy's Avatar
Got it home ran it for 1/2 mile around the yard Friday night started and stop fine. Ran it another 1/2 mile on Saturday started and ran fine. Runs like it was brand new and he didn't replace any parts other than clean the throttle body and new battery.
I have no clue whats up with this machine. Going to put the plow on it tonight and see what happens. Ill keep you posted
Old Jan 30, 2017 | 07:27 AM
  #19
Hope that's all there was to it,but if it acts up again I'd head to tbap/tps wiring as one of the symptoms is that they can run ok for awhile and suddenly start running erratic.
Old Jan 30, 2017 | 07:56 AM
  #20
Vermontguy's Avatar
I will thanks for all the help
